Can someone help direct me on where I should send my tachometer/speedometer from my 1951 Champion to be rebuilt?
1951 Champion
EMEIS Automotive, 218 Iowa Street, Davenport, Iowa 52801, Tel 563.326.0171.
There are a couple of others (1 in So Cal), you should be able to find them on the internet. Expect to pay close to $500. and a fairly long wait. One problem you might find is they may not get the calibration quite right. Unless you have some special reason to keep your original speedo you might want to consider a replacement from one of our Stude dealers. Good luck.
Originally posted by thurms View PostCan someone help direct me on where I should send my tachometer/speedometer from my 1951 Champion to be rebuilt?
I tried to find an aftermarket tach that would fit in the clock hole for my 1950, but I never found one (analog, anyway) that I thought would fit. Has anyone integrated a tach into the dash on a 1950, instead of just mounting it high or low with a bracket?John
1950 Champion
W-3 4 Dr. Sedan
Holdrege NE
Originally posted by Lothar View PostDoes a 1951 Champion have a stock tach? Even as a factory option?RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
Originally posted by Lothar View PostDoes a 1951 Champion have a stock tach? Even as a factory option? I'm pretty sure that they weren't available for 1950.
I tried to find an aftermarket tach that would fit in the clock hole for my 1950, but I never found one (analog, anyway) that I thought would fit. Has anyone integrated a tach into the dash on a 1950, instead of just mounting it high or low with a bracket?sigpic
1950 Commander Starlight Coupe
Regal Deluxe Trim
Automatic transmission
46k original miles, 4th Owner
Originally posted by Lothar View PostHas anyone integrated a tach into the dash on a 1950, instead of just mounting it high or low with a bracket?Jon Stalnaker
Karel Staple Chapter SDC
