Finally after almost a year I got to drive my car on the road,I had good enough brakes and all so I could. The trans was fine in the driveway and parking lot but it has no high gear at all,shifts into...nothing.Sure put a damper on my much anticipated maiden voyage.Anyone have any input on this??
58 Packard transmission woes
Tags: None
Originally posted by SN-60 View PostWas high working when You first bought Your Packard wagon? (were You able to drive the car at all then?)
Was the transmission ever rebuilt? If so, it sounds like the rear sprague is installed backwards (direction of rotation). The stock sprague has brass drag strips, (to reduce clunks while shifting), they need to face to the rear of the car.Bez Auto Alchemy
Originally posted by bezhawk View PostWas the transmission ever rebuilt? If so, it sounds like the rear sprague is installed backwards (direction of rotation). The stock sprague has brass drag strips, (to reduce clunks while shifting), they need to face to the rear of the car.
In regards to checking the AT fluid level.....I believe the Owners Manual as well as the Shop Manual, states to check with the engine running, the fluid at normal operating temperature, and the gear selector in the DRIVE position. If it not in drive, the fluid level will be at a higher level. In drive, the fluid is in full circulation. Just an extra thought. Hope this helps.
Dan Miller
Auburn, GA
Originally posted by Daffy427 View PostOr is there anything else I can put behind it??--------------------------------------
Originally posted by 1962larksedan View PostCheck with the Packard crowd to be sure; word is that a Mopar TorqueFlite is a relatively easy swap..........Bez Auto Alchemy
