Hello fellow Studebakerians,
My 1964 Commander 259 V8 is continually pulling to the right (passenger side) when I press on the brake. We have been trying to remedy this issue for quite sometime now, here is what we have done...
Replaced the upper and lower bushings on both the passenger and drivers side.
Replaced the shock absorber on both sides.
Found the frame was cracked in the spring pocket area, we re-welded the frame and attached a "fish plate" for extra rigidity.
Bleed all four brakes.
On both driver front and passenger front side brakes we have...
Cleaned the brake shoes and the drums...
Replaced the star wheel adjuster (Note: the front brakes have the self adjusting mechanism on them)
Put new brake shoe return springs on.
Took apart the Brake Cylinder, and cleaned all four pistons (2 on each side) making sure they could slide in and out of the cylinder and not bind or catch on the walls [Part No.663429].
Visually inspected all four of the rubber caps and put them back on [Part No. 663428]
Found the front brake adjustment anchor link was a bit loose on the drivers side, so we tightened that up, eliminating any lost motion. Part No. 1558526
Noticed the front brake adjustment anchor lever had a tab that was broken on the passenger side, so we replaced that. Part No. 1558508
After all of this, we naturally had to re-bleed the front brakes.
Next, after ensuring all parts and pieces were put back together, we put the drums on and adjusted the brakes per the shop manual. By turning the star wheel adjuster until the brakes are seized and then backing off 20 notches.
We put the tires back on and hit the road, making our 5 + stops to hopefully align and adjust the brakes, (again as per the shop manual). But each time we came to a stop the steering wheel would still turn to the right.
What gives? Can anyone give me suggestions on what to try next?
Thank you very much!
Superhawk Jr.
Superhawk Jr.
