Some of you may know the story of our Champion my father in law left my wife in febuary after his passing and I spent six months resurrecting something that had set for 30 years. Well I had to hurry on a few things to get it ready by the wedding date. One which I have to redo again. I had to retap and die four holes on the manifold of which where the original bolt broke off in, I wanted to reuse the original part. Well one of the holes on the exhaust end I miss tapped by about 3/32" off center so it just enough to not get a bolt in there so it has a slight exhaust leak when it runs at higher rpms. Anyone have experience or advice how to fill that hole in and re-retap it again? Thanks
Re-retapping Manifold on 49' Champion
I thought of just drilling out the flang on the exhaust pipe but the hole is off center toward the exhaust outlet so i wouldn't be able to get a bolt started on there because the head of the bolt would hit the pipe when trying to start the threads
grind a bit from the exhaust pipe to clear the bolt head meybe. cheers jimmijim. I like the other idea.sigpicAnything worth doing deserves your best shot. Do it right the first time. When you're done you will know it. { I'm just the guy who thinks he knows everything, my buddy is the guy who knows everything.} cheers jimmijim*****SDC***** member
