Anyone recently purchased the 4" heater duct hose from SI for the underseat heaters? How did their replacement compare with the original as far as appearance? Any issues or concerns with the functionality of the replacement duct hose?
Heater Duct 'Hose'?
Heater Duct 'Hose'?
Paul
Winston-Salem, NC
Check out my YouTube channel here: https://www.youtube.com/user/r1larkTags: None
The new stuff has a heavy vinyl coating on the wire spiral. The old stuff was tarred fabric. The new stuff is vastly better. I don't think any authenticity point should be deducted for using the new stuff, since the OEM stuff is unavailable, anyway.Gord Richmond, within Weasel range of the Alberta Badlands
I put that type of vinyl hose on my GT Hawk in about 1994 and it still looks like new and the functionality has not suffered. I have never lost any points for it either.Frank van Doorn
Omaha, Ne.
1962 GT Hawk 289 4 speed
Not really concerned with authenticity as much as staying away from something that looks/feels like thin floppy dryer exhaust hose.Paul
Winston-Salem, NC
Just finished installing mine from S.I. Good stuff. The 6ft. they sell will be more than enough. Screw type dryer clamps (Lowes & others) work well and are superior to the original spring clamp types. Just a thought: if your duct hose was really bad, check inside the remaining steel duct to the floor heater for debris. Found quite a bit in mine. If you order defroster hoses they will be of the same material.
C/B
I have used the SI hose. It is durable and good looking, but does not look like OEM. Most important (to me), I doubt it will flow anywhere near as many air CFM as the original.
IMHO, air flow is important for the marginal heating system.
The OEM is smooth inside, where the SI hose is deeply corrugated by the spun wire. The corrugations cause the air to tumble and slow down. It is about like installing a corrugated exhaust system, and I doubt anyone would seriously consider doing that.
I'm surprised Dean's piece was too short. I've always had leftover. Stretching the hose out eliminates the corrugation and supplies plenty to be cut off for another use.Brad Johnson,
'56 Sky Hawk in process
I just replaced the hose on my 50 Commander. I used what I had on the shelf, 4" vinyl from Clark's Corvair Parts. The length was perfect for the long run, when I cut off a section for the short run through the inner fender. This stuff is probably the same as you get from SI, and it lasts for years in Corvair use. Much longer lasting than the OEM fabric style.Frank DuVal
50 Commander 4 door
Originally posted by 52-fan View PostThat type of hose should be available or can be ordered at most FLAPS. It is still used on big trucks.Mike O'Handley, Cat Herder Third Class
Kenmore, Washington
hausdok@msn.com
'58 Packard Hawk
'05 Subaru Baja Turbo
'71 Toyota Crown Coupe
'69 Pontiac Firebird
(What is it with me and discontinued/orphan cars?)
Originally posted by hausdok View PostWhat is FLAPS? Is that an acronym for something?59 Lark wagon, now V-8, H.D. auto!
60 Lark convertible V-8 auto
61 Champ 1/2 ton 4 speed
62 Champ 3/4 ton auto
63 G.T. Hawk R-2,4 speed
63 Avanti (2) R-1 auto
64 Zip Van
66 Cruiser V-8 auto
