Is it true that the front main bearing is under greater stress on the supercharged Golden Hawks and later supercharged "R" engines due to the additional belt loads and heavy crankshaft pulleys?
Studebaker 'Tech Trivia' Question #7
I am thinking less stressed. The belts are pulling the crank upward, which would help counter the pressure of the pistons & rods pushing downward on the crank. Put another way, main bearings wear more on the bottom bearing half, due to the downward pressure; the belts help pull the crank upward. The length of the snout is irrelevant to the question, as worded.
