1951 2R5 rear leaf spring hangers (units at back of spring - riveted to frame) have the bushing bolts cutting through the bushing housing (the steel part). The bushings are long gone. I have drilled the rivets out and have the hangers off. One of the top leaf's rear eyelets is also cut by the bolt: only 1/16" thick spring where the bolt has cut. I need replacement rear spring hangers, the shackle assemblies, bushings & bolts, and 1 leaf spring. Do I need to change both leaf springs? Is there an alternative spring (Ford, Chev...etc). Anyone with a parts truck...I could email you a list of all items I am looking for. I checked SI...can't put that kind of money in this truck.
Thanks, Ray
Thanks, Ray
