Is oil leaking from the differential of my '56 Sky Hawk an expensive fix?
Leaking differential
Tags: None
They can leak in two different places. The gasket, around the cover, should be an easy fix. Drain the oil, remove all traces of the old gasket, coat the new one with copper spray and put it back together. (flatten out the cover where it's been bent by the old screws). OR, if its' leaking at the input shaft, find a shop to change the seal, not near as easy. The yoke nut was (hopefully) torqued to 170 ft lbs., and is hard to get off.
