View Full Version : Radiator Placement2
adolphpeavy
09-13-2012, 02:48 PM
Guys and gals I need help, again.
Can someone tell me if the radiator in the pic is positioned correct?
The 3 holes are not lining up like they should, I can get the top nut and bolt in but the lower 2 on each side
are physically unreachable.17545
hope you can ssee the pic
RadioRoy
09-13-2012, 04:01 PM
What year and type of vehicle?
Often there are sheet metal "tinnerman" nuts on the radiator, so you only have to get at the screw with a socket wrench.
Also, with any type of sheet metal or flimsy metal, never tighten any of the screws until all of them are started.
candbstudebakers
09-13-2012, 07:30 PM
Don't forget the big shroud need to go on also.
adolphpeavy
09-18-2012, 04:12 PM
Roy, it is a 60 hawk 289 4dr
with the top bolt in you cant even get to the other two
adolphpeavy
Bob, any luck on those parts I need?
adolphpeavy
09-18-2012, 04:25 PM
my mistake it's a 2 door of course
Studebakercenteroforegon
09-18-2012, 10:09 PM
Nuts should not be required - the radiator support frame is tapped. Although more than once I have had to use a nut if the thread was partially stripped, but fortunately on the top location only.
