Is there any way to tell a 6 volt starter from a 12 volt starter, if so, will some one please tell me? Thanks K-Hawk . I did measure the teeth on the purported 6 volt systems flywheel and the teeth were 0.60 apart on the flywheel in the Hawk with a 12 volt system car the flywheel teeth are 0. 40 apart
If one did want to run a six volt starter on a 12 volt system would it be possible to add a resister to provide 6 volts to starter and 12 to rest of car ?
Might be nice to wire a resister into a relay so if was really cold you could switch to 12 volts to starter occasionally , would this also be possible?
