Okay, the '63's fuel pump is faltering (again!) and recently a couple guys in the local chapter told me that a fuel pump from a Chrysler 318 is a bolt-in replacement, and the only difference is that the in and out ports are reversed on the Chrysler pump. So I called NAPA and they have a pump for $20. I told them to hold it for me.
Reviewing Bob Johnstone's site, it looks like the pump does bolt in, but the references there say that you might need to heat up the arm and bend it a few degrees. At the same time, they seem to be discussing R series motors on Bob's site, not the little 259. The guys who told me about using the 318's pump did not mention bending the arm.
Here's my question. If I bolt this bad boy up as is, is it going to be fine for my engine even if the arm is a hair off, or should I bend the arm? Not having picked up the part yet, I can't physically line them up to see the difference. If I do need to bend it, will a mapp gas torch be hot enough to do the trick? That's the best I can do right now in my shop.
Thanks guys!
(PS - Yes, yes, I realize I could order the right part straight from a Stude vendor, but I'm off tomorrow, and I really want to get some time to drive around. Plus, with everyone in South Bend, it's going to be a week before any of my regular vendors could even get back to me anyhow.)
Thanks guys!
