Hello everyone.
I need to disconnect the speedometer at the firewall and don't know how.
I dont know if is supposed to be this way or not,but where it comes out of the firewall,the cable rubs against the the rear portion of the rocker cover. also, the nut is very tight,so i put a little WD-40 on it.
I am in the process of repainting both valve covers,and dont want the cable to ruin the job. The speedometer cable is routed over the overdrive cable, and i want to route it underneath.
If i disconnect it at the firewall, what happens then? The speedo is fine, i just want reposistion the cable.My Studebaker is a 16G8F2,a late 1955 Commander collum shift with overdrive.
Any ideas?
Thanks-
55CMNDR
Any ideas?
Thanks-
55CMNDR
