Beat-up by my ignition switch
  • Ignition: Beat-up by my ignition switch
    OK, my left arm isn't what it used to be since I shattered my shoulder.
    But tonight I gathered up my courage once again to have a go at trying to mount my new ignition switch in the dash of my GT. No matter how many times I've tried, I never seem able to push the switch far enough into the bezel so I can turn and lock it. Are there any tricks to make this work?
    Tonight, I took the tension spring and squished it in the vise, hoping a few daysof that might reduce the tension a little.
    I did get it pretty close once months ago without the plastic washer in place. But i'd like to do it "right" if I can.
    Paul
    I finally have a Stude I can drive! (sort of)
    1962 GT Hawk, 4 speed, a/c
    I can understand what your going through. With the plastic washer ( which difuses the light for the switch) it makes it even harder. What I have done in the past is put a dot of white out even with the ignition cylinder to assist in guiding it into the bezel. It's still a bit of a push but at least that hard part is done with. If your not concerned about the light for the switch, then leave the plastic ring off & youll have that much less tension to overcome.
    60 Lark convertible V-8 auto
    61 Champ 1/2 ton 4 speed
    62 Champ 3/4 ton auto
    63 G.T. Hawk R-2,4 speed
    63 Avanti (2) R-1 auto
    64 Zip Van
    66 Cruiser V-8 auto
      Are you sure that you have the right bezel? I seem to recall bezels of two different depths, for different applications. Maybe you have a short one and need a long one?
