the water pump is really noisy and I suspect it will have to be replaced, anyone know of a reasonably priced pump, I'm debating the possibility of sending mine in for a rebuild, anyone had any experience with this?
1963 studebaker Hawk water pump
Studebakers West has them. If you order one from them, you car will still be operational while it is being shipped. Might be better than having it off road for the time it takes to have the old one rebuilt.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
Look at the Studebaker vendors sites for waterpumps, they are available and plentiful.
Then look at Bob Johnstones Studebaker Tech site under waterpumps.
There are dimensions and images of the correct impeller spacing.
Check the new one, adjust it with a gear puller on the impeller if it is not correct..
Make sure to use the thin gasket.
Correctly spaced and using the correct gasket makes all the difference.South Lompoc Studebaker
