The '55 has a basic timing pointer on its 289. There are three marks on the dampener; UDC(Upper Dead Center), IGN(Ignition), and IN-OP(Intake Open). Before you drop a distributor in the engine and rotate the engine around to TDC, which timing mark is that pointer supposed to line up with at TDC, to align the distributor with piston #1(UDC, IGN, IN-OP)? I thought UDC, but I think it's IGN .....
Basic Timing pointer question for '63 289
Found the answer, UDC indexes Top Dead Center on the #1 piston on the compression and exhaust stroke, IGN indexes when the piston fires, and IN-OP indexes when the #1 intake valve opens. UDC is needed when setting valve lash(the crank will be at UDC twice for the compression and exhaust stroke), so it gets spun twice. IGN is needed to be in alignment with the pointer when the distributor gets dropped in.
In my case I needed to know this because I am redoing some stuff on the trigger wheel, and the VR sensor needs to be aligned with the 5th tooth away from the missing tooth since it's a V8, and that the sensor needs to reference TDC and the crankshaft centerline. The engine needs to be at TDC for this ignition system to work, and I believe I may have gotten the timing off by aligning it on the exhaust rather than compression stroke. The end result was vehicle backfiring into the intake and exhaust manifold, and refusing to start, so that needs to be addressed. The vehicle also isn't running at the moment due to some modifications that went awry last month, and discovering the VR sensor bracket got loose and threw everything out of alignment down there. So we're putting everything back to the way they were before this happened1964 Studebaker Commander R2 clone
Originally posted by Cus63 View PostThanks Ben,
In the mean time I have scaled up this template, could you please check against your marks,
regards, Cus
