The newest part of an ongoing series. I'm now in the process of running all the tubing for the AC vents after I finally came up with a final placement for the outer vents. I'm also completing some knee bar/package trays that will hold the outer vents and also cover the lower part of the AC unit on the passenger side. Not seen is how I shortened the glove box liner to allow space for the unit and ductwork - the dash is not ready to go into the car until I finish all this work. I am also doing the final work on the wiring (Painless 18 circuit unit). Whew!:
What it takes to install behind the dash AC in a 1966 Daytona
Man, that's a lot of hose!
What is the console from? It all looks very sanitary.
The center console is made from two pieces from this place:
truck console, car consoles, truck accessories, classic truck car center consoles, chevelle, nova, camaro, classic rides, pickup
Their stuff is a little pricey, but it's very high quality (you could use the bare gelcoat as is or painit it with very little prep) and it beats starting completely from scratch. I made a cardboard template of the console once I received it and used that to figure out exactly how to cut it down to make it fit and how to mount the gauges, etc. Better to cut too much cardboard than too much fiberglass.Scott Rodgers
Los Angeles
SDC Member since 1989
\'60 Lark HT
\'63 Wagonaire
\'66 Frankenbaker
I've finally finished configuring the Vintage Air Mini unit in my 66 Daytona. Note the reversed defroster vents. I'll actually have a glove box too, but it will be a tad short. The last 2 shots show the knee pad/package trays I built to hold the outer AC vents (you can see the hoses for them dangling in the pictures with the test dash removed). I need to fix some things on the console - after that the new dash goes in and I can hook up the electrical. Almost on the road:Scott Rodgers
Los Angeles
\'60 Lark HT
\'63 Wagonaire
\'66 Frankenbaker
