We have a 65 commander that we are in the process of taking the rear end apart. The car has a v8- 283 with a automatic transmission, a rana 44 with 3.31 gear ratio. My questions when removing the brake backing plates from the axle housing there was very thin shims located there 3 on the right and none on the left. Do they adjust clearance on the backing plate or what? Any input would be appreciated. The service manual only says use as needed!
Thank You
Thank You
