Wanted any input from those who have either reworked the C-cab front suspension with a quality IFS or a clip from any other vehicle that is a simple install. Any and all experiences will be helpful in the decision making process.
IFS or front clip for 1953 C-cab pick up
I haven't done one myself, but a Volare front clip, the kind that used the transverse torsion bars, can be fit right under the existing frame rails and welded on. Used to be a popular conversion. The Volare K-member is fairly flat on top, and sized such that the truck's frame rails pretty well match up to the flat areas. Ford Aerostar front clip might be another one to look into.Gord Richmond, within Weasel range of the Alberta Badlands
Originally posted by mike super View PostWanted any input from those who have either reworked the C-cab front suspension with a quality IFS or a clip from any other vehicle that is a simple install. Any and all experiences will be helpful in the decision making process.
Why stop at a front clip. I was at a car show yesterday with with a fellow that dropped a 52 on an S-10 frame and you'll not see a nicer conversion. However, he said that right after he started the conversion, a friend of his told him that a late model Dodge Dakota frame was made for the swap and gives you a nice suspension and R&P steering. He looked into the swap and said he wished he had gone with the Dodge. That way you have completely come into the 2000's. Just a thought.
Bob
Ford Aerostar Van suspension BOLTS in very easily.Bez Auto Alchemy
No on the ford aerostar for me anyway. I had one and I had to replace the rack twice and the suspension ball joints sucked too. I would NEVER put the crud under one of my Studes.
Something like this would be my choice and worth the extra money
Or this one since the control arms are tubular and it is cheaper, may be a bit more work to weld in but not hard at all.
Jon Stalnaker aka sdude just had a Fatman clip done on his '49.
He is very happy with it. It was done in conjunction with installing a GM 5.3 motor and trans.
Let me add that Fatman has kits that are pre-engineered for many specific Studebaker models with holes all lined up for the sheetmetal, core support and other attchments.Last edited by Pat Dilling; 04-29-2012, 08:43 AM.Pat Dilling
Olivehurst, CA
Originally posted by Pat Dilling View PostJon Stalnaker aka sdude just had a Fatman clip done on his '49.
Let me add that Fatman has kits that are pre-engineered for many specific Studebaker models with holes all lined up for the sheetmetal, core support and other attchments.Jon Stalnaker
Karel Staple Chapter SDC
Thanks everyone for all the information. The most intriguing to me is the 2000 something Dodge Dakota complete front to rear chassis to include the motor and trans. Problem is finding a reassonably priced donor. I am going to liik into it. Did that on my 58 Dodge powerwagon....2006 26,000 mile Dodge 1500 mega cab with everything to include a 350 hrmi for 7500.00 ! The other set up is the Fatman IFS Jon used with 5.3 chevy LSD motor, Pat refer's to. That is a ver fine job befitting a very nice 49 Jon. I use the 5.3's in all my Packard refits. They are powerful and geared low and half the price of the Corvette stuff. The Helix Kmac refers to is priced well but the Fatman gives you a sway bar....11 inch rotors....brake lines....upgrade to 2 inch dropped spindles....free shipping....upgrade to power rack.....so the price is close to the same. That gives me a few options to chew on....again many thanks.
Originally posted by kmac530 View PostJon,
You didn't have to loose the horn button, just the ability to use it as a horn because the wire could not go thru the steering rack anymore, correct? You still have the button in place right?Jon Stalnaker
I saw a 55 C cab back in 85 , used 84 Corvette suspension. The inside of the K frame is 1/2" narrower than the C cab frame, used 1/2" plate and welded it in a 1/4" in on each side. I'm pretty sure that the truck is in either the LA area or Durango Co. area, or back & forth between both.
Jim"We can't all be Heroes, Some us just need to stand on the curb and clap as they go by" Will Rogers
As of Veterans Day 2017, IHF has flown 2,450 WWII, Korean, and Vietnam Veterans to Washington DC at NO charge! to see their Memorials!
