Ok boys and girls. I've decided against making a street rod out of my 50 2R. I will stay with the original 6 and 3 speed with over drive. I need some advise on a few things I had trouble with last summer.
The carb on the truck now, started leaking a bit and would only run right with the choke pulled part way. This carb is from an old Chrysler. What carb should be on my truck?
The over drive unit was never hooked up on the truck when my dad had the tranny put in. Can a person use a toggle switch in place of the system that was on the throttle? I really need the over drive and maybe even a higher geared rear end (the truck was screaming at 42 mph).
My truck has a radiator for a V8 mounted on the outside of the core support causing it to be too far from the fan. It over heats during parade driving. I would trade my radiator for one designed for the 6.
Finally, I am having problems with one of the front brakes grabbing. Are spring kits and other parts still available?
