I found a brand new master cylinder labeled "63-64 T cab truck". It looks the same as what was used on disc brake cars. Is it actually the same or is it for trucks only? Thanks.
MC interchange question
If it is labeled for trucks, It means it's for drum brakes, so , it would have a residual pressure valve. Disc brake cylinders don't have one.
Other than that, what is the bore diameter?Bez Auto Alchemy
The 1/2 Ton Champs get a 1 inch bore and the 3/4 Tons have a 1 1/8 inch. The Correct '63-'64 Truck Masters have a fruit jar lid style that screws on with threads on the outside of the Master.StudeRich
My Zip Van has a fruit jar style master cylinder, but it looked like a single rather than a dual master the shop manual says it should be. I had thought it had been replaced at some time with a Ford master but maybe not? I'll measure the bore tomorrow. Another thing too why I thought it was replaced is the lines had bushings on them to step down to the smaller size on the master.59 Lark wagon, now V-8, H.D. auto!
60 Lark convertible V-8 auto
61 Champ 1/2 ton 4 speed
62 Champ 3/4 ton auto
63 G.T. Hawk R-2,4 speed
63 Avanti (2) R-1 auto
64 Zip Van
66 Cruiser V-8 auto
I thought a Champ M/C looked like an Avanti but larger all the way around. The bore size and valving would also be different.
Warren, a zip van used a rare (Trk part numbered 6XXXXX) dual M/C but the Lark dual M/C works. Look up the interchange #'s on the forum for 61 & up Larks. If I recall correctly-thats what James found and it worked.
