When replacing brake hoses on our 40 Commander I notice in the SI catalog copper washers. Should those be replaced when brake hoses are? Is it best not to reuse the old or are they not included with new hoses?
Copper washers
Use new copper washers. There are usually radial grooves in the sealing surfaces of the fittings. The soft copper washers mold themselves to those grooves, if you use new hoses/fittings, the grooves impressed in the copper won't match the grooves in the fittings and you will risk having a leaky system.
Usually they only take one per fitting, BUT, there are many different thicknesses, they are cheap, get a few extra. If you can "pick & choose" get the thicker ones.
Jim"We can't all be Heroes, Some us just need to stand on the curb and clap as they go by" Will Rogers
As of Veterans Day 2017, IHF has flown 2,450 WWII, Korean, and Vietnam Veterans to Washington DC at NO charge! to see their Memorials!
Check first. My hoses came with them!
