Currently, the car has a stock fuel system from fuel tank to carburetor. The issue is hard starting when the car sits for a long time and the fuel bowls have "dried out".
I have a flow through electric pump ready to install. The question is - do I take the existing mechanical pump out of the fuel circuit so just the electric provides the fuel to the carb full time or do I use them both in series using the existing fuel lines from the back of the car to the mechanical fuel pump with the electric used momentarily pushing fuel through the mechanical pump just to fill the carb fuel bowls for an easier start.
My concern is the diaphragm in the mechanical pump getting damaged or blown out by the pressure from the electric pump. Also, I'm not sure if the electric pump will work as the full time pump with the R2 setup given the mechanical pump has equalized pressure with the supercharger.
Thanks for the help.
