View Full Version : 6x2 log manifold
candbstudebakers
01-13-2012, 10:29 AM
I an going to sell this 6x2 log manifold it is build for the Cadalic I think as it is a little longer than the Studebaker and has larger ports, it could be altered to fit Studebaker with some work, if any one is interested let me know.ect. I have no carbs for it but my self was planning on using the original late model Stude ones, there is room to re drill the bolt holes, it will cost some one some buck before this ever get on an engine but once it is fitted and working you have one of a kind. $250.00 plus shipping.
http://i691.photobucket.com/albums/vv271/canbstudebakers/IM002376.jpg[\IMG]
[IMG]http://i691.photobucket.com/albums/vv271/canbstudebakers/IM002377.jpg
http://i691.photobucket.com/albums/vv271/canbstudebakers/IM002378.jpg
SN-60
01-13-2012, 05:15 PM
Sure reminds Me of the days when gas was cheap! Wonder why the exhaust crossover ports aren't completely blocked off? Top end use in warm climates ONLY with this bad boy!
52-fan
01-14-2012, 08:51 AM
I believe those tubes are equalizers between the logs. No exhaust heat on a manifold like this.
I wonder how that thing would run with only a functioning carb in the center of each bank?
SN-60
01-14-2012, 10:41 PM
52-fan--- Yes, I get the equalizers, but without that exhaust port completely blocked off, I think those center carbs would roast. All-in-all, this isn't streetable.
Bellingham Studenut
01-14-2012, 10:57 PM
I have 2 of these in the Stude version, but 1 is without carbs. The Drag Star manifolds were for just that, drag racing, so gas usage wasn't the big cost when racing then, or now.
The one with all 12 bbl's functioning is quite intimidating to people looking at a Stude engine with it. It was street driven with block off plates for awhile, running just on 2 center carbs.
It was running in a convertible 53, with LaSal transmission the first time I'd seen it and when the owner made it more streetable with single 4bbl, I wanted to know were the manifold went (so it went home with me).
James
candbstudebakers
01-15-2012, 11:51 AM
James
James can you post some pictures? if might help others want this one before I but it on e-bay for the caddy owners.
Bellingham Studenut
01-15-2012, 08:44 PM
Bob,
This Drag Star was made for Studes.
12 barrels to shoot down the track (Six 2bbls).
http://forum.studebakerdriversclub.com/attachment.php?attachmentid=13370&d=1326680595
http://forum.studebakerdriversclub.com/attachment.php?attachmentid=13371&d=1326680627
The one on left below is a Edmonds, with more common two 2 bbls.
The one on right is a Six Pack Smolgen.
Most people know what the red snail, whirley thing in the middle is.
http://forum.studebakerdriversclub.com/attachment.php?attachmentid=13372&d=1326680659
I'm sure someone will enjoy setting up Bobs manifold.
James Bell
SN-60
01-15-2012, 11:33 PM
The triple setup, and a pair of Offy style rocker arm covers on a Studebaker V-8 engine, would WOW them at the shows!
