So not to knock the Studebaker engine design, but does anyone else have an issue with the rod bolts on a Stude V8?
I have built dozens of VW motors from 1200cc 36hp rebuilds to 200+hp 2274cc Weber IDA 10 second drag bug motors and everything in between. Also Toyota 8rc, 18r, 20r and a 22r motors. And 4 SBC from 265ci to a 383. Then I have even built a few BBC including my ElCo's 396/402 a 454 and a blown 468 750hp monster.
I do not prefer this rod bolt design. The bolts fall into the motor and are just awekward to deal with. I have had rods with actual bolts thru the cap into the rod. I have had studs that are screwed to the rod with nuts on the studs to hold the cap on. I have had bolts in the rods, similar to the Stude design, but they press in or have a type of knurling that grab into the rod and hold it in place while you fiddle with the caps.
I like removeable rod bolts, I just wish these were tighter and held their position better.
Am I missing something positive in this design, or do others not prefer it as well?
What good points are there in this design?
No life and death problem here, just curious.
