What is the correct color for the wiper motor, for the 61 Lark W4? Thanks.
Wiper Motor.
According to the June, 1994 issue of Turning Wheels, all electrical components were black in the '61 Larks. The block and heads were silver-gray and the valve covers were red. I hope this helps.
Rog'59 Lark VI Regal Hardtop
Smithtown,NY
I think the "electrical components" mentioned in the article refers to the starter, generator, regulator, and the like. All of the wiper motors that I remember seeing have been a metal finish (anodized?) unless someone had painted them later."In the heart of Arkansas."
Try cleaning with paint thinner, with a rag and tooth brush. Don't soak. Then brush lighty with a rotary brush (brass). Clearcoat. It gives you the natural finish, which was what was on them new. (no paint). Not a very good shot, but here's mine, after doing it this way and putting a new decal on.
Originally posted by drnittler View PostWhat is the correct color for the wiper motor, for the 61 Lark W4? Thanks.
Motor Case is Cadmium Plated
Commutator Housing is natural finish Aluminum
Gear Housing is natural finish Aluminum Die Cast
Gear Housing Cover is Cadmium Plated
Mounting Bracket is Cadmium Plated
IF ...it’s an AUTO-LITE or REDMOND Motor, hopefully someone else will chime in with that info.
Good Luck!!!
FWIW the 6v redmond motor on the earlier cars:
gloss black for the motor
bare die cast aluminum for the gear case
cad plated steel for the cover over the gears.
gloss black for the sheet metal bracket the motor attaches to that then attaches to the firewall.
Jeff in ND
