I know that during the 1965 model year tapered axles were phased out, but does anyone know at what serial number? If you take a wheel off can you tell which kind of axle a car has? My Daytona's brakes are stuck on and the drums won't come off. It thought it would be good to know what kind of axle I'm dealing with. This car has serial number C5I0225. Thanks.
Tapered axles phased out when?
If you have a tapered axle it can be clearly identified by looking to see if it has a castelated nut with a cotter key present at the center of the wheel. On flanged axles the area at the center of the wheel will be flat.Frank van Doorn
Omaha, Ne.
1962 GT Hawk 289 4 speed
Omaha, Ne.
Yep that is a tapered axle, time to try and back off the brake shoe adjusters and try to pull the drum- hub assembly with a suitable puller.Seek advice if you have not done this before!!!Frank van Doorn
Omaha, Ne.
Omaha, Ne.
The bad news is that even after weeks of letting liquid solvents work, none of the adjusters will budge and it seems as thought the shoes are in a groove with a ridge keeping the drums on. If brute force must be used, what's the best course of action?"Madness...is the exception in individuals, but the rule in groups" - Nietzsche.
Hi Dick,
I don't and if it's something special I doubt the shop working on the car has the right one either. If it's a special tool please bring it!
Hi Dick,
