Hope this question doesn't confuse all of you! I have a Dana 70hd rear end I
removed from a Dodge framed motor home (M500 chassis). The RV had been in an
accident and was at the local wrecking yard. My plan has been to use it on my
1948 Studebaker truck restoration.
When I removed the axle I also took the spring mounts off of the Dodge frame to
use on the Studebaker. The problem I have now is I have misplaced my notes and
have no idea how far apart the spring mounts should be on the frame. So if
someone out there has a 1976 M500 chassis RV with a Dana 70hd, could you please
measure the distance between the spring mounts? Thanks, Neal
BTW I mean from front to back
