I have a 55 Commander coupe V8 (3 speed standard ) with a four barrel carburator#22198A .After a lot of mechanicing I found that no fuel was passing up the passage to the accelerator pump spray jets. I filed the threads off of part of the bolt holding the spray jets and now it works. My question---Is the bolt holding the pump spray jets supposed to be a part number ? It seems to me that it should be and that someone(previous owner) switched it for a bolt.I have a manual but can't find if I have the correct carb or if there is a special part(hollow bolt) that is missing.Do I have the correct carb?Is there a specal part missing?---Jim in Honolulu
