So not having a mill at my avail, I am just not able to make the GM mini starter work on the Stude. The gear itself will work, but it wont extend quite far enough for me to be comfortable with it. The stock starter throws out at least 5/8" maybe a bit more but the mini starter is about 1/2" maybe a bit less. That engagement is a bit too shallow for me. If i could get the bendix gear on the starter to be a few thousandths from the ring gear it may throw out far enough, but the face block of the mini starter would need to have a 1/4" milled off and I dont have that capability.
It could be done for you machinist out there.
So I am back to making a stock starter work. I have a 3 speed w/OD trans from a '52 Commander. I will be installing a '63 259 in it this week.
The starter in it has a few numbers on it. There is some sort stamoing I cant read looks like 2 xx's but then there is an 8 the a space then 64. Then under that there is a 3537. It looks like this.
8 64
3537
First off, what do I have currently?
Second, is there a part number that I can use when I convert to 12v?
Third, Where can I find one?
It has been suggested that I just have mine rebuilt, and that may be what I need to do, but, I just feel like it may be a waste to rebuild it if it is 6v and then burn it up again in short time. I have used a 6v starter on 12v converted bugs before and they work fine, for a while.
Input?
12v to 6v reducer is always possible, but I hate that slow crank of the 6v starters personally. I want a daily driver here.
8 64
3537
Input?
