After it has been sitting in my barn for 30+ years, I have decided to resurrect my 1960 Hawk (3 spd with OD). I recall that when I last drove it, the gears would grind when shifting into 2nd gear unless I double-clutched it. Any suggestions as to what I should check to correct this problem ? Thanks in advance.
Transmission Grinding into 2nd gear
Synchronizers in the transmission are worn. It will have to come out to have them replaced.Frank van Doorn
Omaha, Ne.
1962 GT Hawk 289 4 speed
That's a common problem with the Borg Warner T86 transmission. The blocker ring wears on second gear causing the grinding. I agree with 41 Frank, in order to correct the problem, the trans will have to be repaired. Bud
Another caution is to not use 85/90 gear oil. The additives in it attack the synchronizers. Use straight 90 weight mineral oil if you can find it, or straight 40 wt engine oil.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
