Does anyone know what the seat belt laws are for a 1958 that wasn't equipped with them from the factory in Indiana and if you drive to other states and also would it a hole drilled in the floor be strong enough to do any good and would it devalue the car. It is a Golden Hawk.
seat belt laws
Usually if the car was not originally equipped with them, then it is exempt from state and local seat belt laws. However, in the interest of safety I would put in seat belts. You have to reinforce the top and bottom of the body floor mounting holes. There are specific rectangle reinforcements made for this purpose. I do not believe that the modification would devalue a car. All judging manuals consider seat belts to be a safety item and do not deduct any points.John
1963 Avanti R2
Marshall, VA
Hi John, my name is Anthony, aka Blu Stu. I have a 1950 Champion, blue-colored of course, that for reasons understood didn't come with seat belts. Do you know of any outfitter who supplies seat belts with the rectangular reinforements you speak of? I've got a 7-year old, I need to worry about when we go cruising. Please let me know, thanks.
Good points there.
My 1962 Lark never had seatbelts; but, I plan to install 3 point lap/shoulder ones at least up front and possibly for the rear seat as well once the car is otherwise roadworthy (engine installed, disc brakes, etc.)--------------------------------------
Originally posted by Blu Stu View PostHi John, my name is Anthony, aka Blu Stu. I have a 1950 Champion, blue-colored of course, that for reasons understood didn't come with seat belts. Do you know of any outfitter who supplies seat belts with the rectangular reinforements you speak of? I've got a 7-year old, I need to worry about when we go cruising. Please let me know, thanks.--------------------------------------
Studebaker International also sells seat belts, they are a kit, with a VERY large washer (about 3") that goes under the floor. Of course, your floor needs to be solid too!
Jim"We can't all be Heroes, Some us just need to stand on the curb and clap as they go by" Will Rogers
As of Veterans Day 2017, IHF has flown 2,450 WWII, Korean, and Vietnam Veterans to Washington DC at NO charge! to see their Memorials!
I know in 1963 the anchor plugs were installed on all Studebakers so adding belts is simple. Don't know if earlier models had them.Brad Johnson,
'56 Sky Hawk in process
Originally posted by 50starlite View Post1962 was the first year to have reinforced anchors but no seat belts. I bought a new 62 and the lap belts bolted right in.--------------------------------------
Originally posted by 1962larksedan View PostThose rubber plugs: are they the ones that point downward? My 1962 Lark sedan has no belts but has what appear to be some reinforced threaded anchors in the floor but with no metal bolts passing through.Skip Lackie
Originally posted by Skip Lackie View PostYes. The bolt anchors were installed in all cars several years before seat belts became mandatory. Sugggest that you run a proper-sized tap through them before trying to install seat belt bolts. Those rubber plugs don't seal all that well, and the floor anchor threads will be a bit rusty.
(and my being a DC native, I understand rust all too well )--------------------------------------
I just did this on my 64 convertible, it originally had seat belts in the front but the rears had the rubber plugs. It takes a 7/16 fine thread tap. I ran it thru them all before putting in the eye bolts. I was really surprised how little rust there was on the rear ones where the rubber plugs had been. I guess you could say the rubber plugs did a great job for 45 years. I got the belts from SI as they match the style for 64 and all eight bolted in nicely.Milt
1961 Hawk 4-speed
1967 Avanti
1961 Lark 2 door
1988 Avanti Convertible
Member of SDC since 1973
