I've been working on my Hawk the last couple of days. I welded up a jig for my floor jack to remove the differential by myself. Cleaned up the backing plates I bought in South Bend this last spring... Thanks to Kent Fedor. Had the 3.54 Ratio Dana 44 changed to 4.55:1... Thanks to Bob Pederson and the purchase of the Dana 44... thanks to Dave Arnold.
The Hawk is now 2' off the floor with the differential out and the new one ready to install. I welded up the traction bar brackets today on to the differential tubes. Had to temporarily install the new 44 to set up the position of the brackets. Glad that part is done. Did a stupid thing the other day by install the inner axle seal before welding on the brackets... really dumb when your heading into a long weekend and had a hard time to find an inner seal at the local FLAPS. These guys are more stupid than me.
Anyway I found some new ones (hopefully they are correct, picking them up at noon tomorrow) so I should be good to go and install the Fairborn Studebaker Axles I picked up this spring as well. New rear brakes as well are going into this Strip Differential. I figure with two differentials all set up and ready to go I should be able to swap them out in 4-5 hours when ever I want to get some better off the line performance.
There are a few other things I want to take care of while the Hawk is up in the air. I have found that the transmission control valve is leaking causing a puddle on the concrete floor. My transmission guy gave me a one way valve to install in the return line from the transmission cooler. Hopefully this stops the torque convertor from draining while the car is idle.
Would like to change the supercharger oil and fix a R3 Header leak with some new gaskets that I found in my stash..
I also want to attempt to fix the power steering control valve leak once again. I lost all the Power Steering coming home from South Bend this last spring and cut the belt off on the way home. I've been driving the Hawk without power steering all summer and it's time to fix that as well.
It's hard to take your car off the road when all you have is one car for the summer... my son has been using my truck all summer for work and hope to have it back this week sometime when he settles down into University mode once again.
I'm looking forward to see the performance change with that 4.55:1 ratio.... Sunday can't come soon enough.
We have had a really hot and humid summer up here in Southern Ontario and broke down earlier this summer and bought a 220V 18000 BTU window shaker air condition for my shop. I doubt I could be doing this work right now without it. Got it down to about 76 degrees in the shop this afternoon, a really nice temp to be working in.
Here's a pic of today's work.
Allen
Allen
