Hello I'm looking at a NOS block in a factory crate the owner has not opened the crate and is not in a hurry to do so. But the part number is 081723. Also NOS heads with a casting number of 535107. I looked the heads up on jonstones site but they weren't listed. He said that number was cast into the head.
Part numbers need deciphered.
That old stenciling can be hard to read. I'm nearly certain the part number is 681723, which is shown as a 232 short block for 3R 28 and 38. Of course it could be used to replace any 232. A short block engine consists of the block assembled with pistons, rings, crankshaft, rods, cam, all bearings, timing gears and cover, oil pressure relief valve and flywheel bolts.Restorations by Skip Towne
