Does anyone know what the bore is for the single chamber master cylinder used with 63-66 disc brake equipped cars? Is it one inch or something else?
M/C for disc brake cars
Yes, 1" is correct.Bez Auto Alchemy
Originally posted by Scott View PostThis is on my 66 Cruiser. I was looking at either Cardone 10-36706 or Wagner 36706.--------------------------------------
Originally posted by Scott View PostI don't know if that will work with disc brakes, though.--------------------------------------
early 70's Chrysler will bolt right on, you will need to adjust the rod between the M/C & booster I do not remember the part number right now, but I think if you look in April 2001 Turnering Wheels in the tech section, the number is in there.
Jim"We can't all be Heroes, Some us just need to stand on the curb and clap as they go by" Will Rogers
As of Veterans Day 2017, IHF has flown 2,450 WWII, Korean, and Vietnam Veterans to Washington DC at NO charge! to see their Memorials!
Somewhere I read that a 1973 Plymouth Gran Fury (?) has a power booster/ m/cyl that is very similar to the Stude set up.
If Scott decides to go the split m/cyl unit, which brake line goes where?
Also, will we need to put a proportionng valve in line?George King
Grants Pass, Oregon
64 Station Wagon with fixed roof (Canadian Car)
66 Station Wagon with fixed roof. Project car, complete For Sale...
64 Wagonaire sliding roof South Bend car. For Sale...
63 GT Hawk
51 Champion Starlight Coupe For Sale...
Originally posted by Orestudeguy View PostSomewhere I read that a 1973 Plymouth Gran Fury (?) has a power booster/ m/cyl that is very similar to the Stude set up.
Also, will we need to put a proportionng valve in line?--------------------------------------
Originally posted by Studebakercenteroforegon View PostIf we are speaking about Lark/Avanti firewall mounted disc brake master cylinders, 1" is not correct. These cylinders are 1-1/8" bore.
When using any Chrysler Single system round reservoir Master Cylinder, (use only 1 inch) you must remove their residual valve (when included), rubber boot, their type of Piston retaining cover and (2) screws and replace with the SINGLE, simple beveled head screw and retaining ring from a Studebaker M/C.Last edited by StudeRich; 08-19-2011, 10:46 AM.StudeRich
Well my head is spinning, but hopefully George understands all this. The bottom line is that I know I can get the correct MC from a Studebaker vendor, but as much as I want to support those guys this is a case where if I can find the correct replacement for $50-$75, it makes more sense to do that than spend $150 to get one (probably the same item) from a Stude vendor. It would also leave me more money to get really unique items from them."Madness...is the exception in individuals, but the rule in groups" - Nietzsche.
- Likes 1
Scott,
I know what to do.
But it's your car and your cash. Let me know!!!George King
Grants Pass, Oregon
63 GT Hawk
