My freshly rebuilt 1964 259 V8 has an Edelbrock 1403 carb with a half inch aluminum spacer and several carb mounting gaskets both over and under the spacer. My hope was to insulate the carb from heat, thus attempting to avoid vapor lock and fuel boiling out of the Edelbrock. Well, I've not experienced vapor lock with it yet while driving, but I've got to crank it way, way too much to re-start after driving on hot days.
1) Should I have used a phenolic spacer rather than the aluminum?
2) Any other ideas ??? (Car does seem to run OK after it gets running, but, it seems a bit gutless).
Thank you,
Larry
Thank you,
Larry
