55 President 4 barrel carb
Been sitting for who knows how long. I got it fired up but I'm pretty sure at least one jet is clogged and the rest probably dirty.
I assume the two front jets should spray an equal amount of fuel in an even pattern at idle?
The drivers side is barely dribbling and seems more plugged than when I first started it.
I also assume the two rear don't really spray till the rear two barrels open up?
How should I go about fixing this up? Just not sure if I have to take a lot apart or if there's quick easy access to the vitals. I'm sure I could figure it out but thought you guys might have some good tips.
