Okay, I just purchase a 2 door Studebaker 1950 Champion. Inside of car, I have a Sun Visor that fits the outside front of car. What is the diff. between 4 dr. vs. 2 door sun visor. The sun visor is setting inside of car. Do you have pictures of the diff.
What is the diff. on outside sun visor 2 door Vs 4 door
This is a OUTSIDE roof mounted Visor, Right?
And as far as I know, all '47-'52 Studebakers, Champions, Commanders, 2 Dr. 4 Dr. have the same Windshield and W/S frame, Roof and forward body except '52 Hardtops and all Convertibles, so there should be no difference, who said there is?Last edited by StudeRich; 06-06-2011, 11:23 AM.StudeRich
I suspect that there were different vendors for the visors, although I see no reason for them to be for different models. There were some differences, some models had a split windshield, some a one piece, if I remember correctly. The center bracing might be different, but again, I would suspect each vendor would have brackets for each style.
I believe that the difference would be for one piece windshield versus two piece windshield, not two door versus four door.Gary L.
With a split windshield the visor center support would normally be clamped directly to the windshield divider strip. Many of these visors were two pieces and a firm center support is crucial to their stability.
To mount the visor to a car with a one-piece windshield there was usually a rod that attached to the roof and cowl, to which the center support could be attached. Some cars with two-piece windshields have also used this extra rod, depending on the manufacturer.
Studebaker also had a roof bracket to mount their one-piece visor to a car with one-piece windshield.
Yours should either clamp directly to the divider strip or to a center support rod.
I don't have a picture of that but someone here should.Brad Johnson,
'56 Sky Hawk in process
This recent thread may help. Or not. Yes, probably the main difference is the center support. Clamps to the center w/s bar on a two-piece w/s. A one-piece w/s needs a different support system, as shown in this thread:
http://forum.studebakerdriversclub.c...ndshield-visor.
Needs either a support rod to the cowl or a bracket on the roof.KURTRUK
