IF it is a '51 COMMANDER I think it will work... not sure about a Champion. However, ISTR that you have to swap the WHOLE front end... if you try to mix 'n' match it doesn't work because the kingpins and lower knuckles are different (sometime in the 60's the parts were revised to change the caster? I think? They're different, anyhow.)
You don't like the solid inner bushings? I'm sure there'd be people happy to take them off your hands...
If you decide to use the disc brakes make sure you get the rear brakes from your donor car as well.
good luck,
good luck,
