This one is a puzzler for me but I know there is someone on this forum with the answer. My 57 silver hawk does not have a safety switch. I found out the hard way. I have purchased a used switch and I need to install it. I have attached photos of the switch.
I have also found the wiring diagram showing where the four wires from the switch go:
1. Black-oak to the light switch.
2. white-red to the ignition switch.
3. white-black to the back up light switch ? Where is this?
4. white-red to the starter solenoid
Where I get lost is knowing which post on the switch connects to which colored wire and there are multiple connection points on the unit being connected to on the terminating end of each wire. Which point does the wire connect to?
If anyone can look at their connections and tell me where each end of any one of these wires goes
it would be greatly appreciated. That would cut down the odds of my screwing up again. Thanks
