My chassis is closer to completion. Here is a link if anyone cares to look.
Studebaker Chassis closer to completion
Fair enough Bob. The 9" rear has a nodular center section that I had built in Mooresville,N.C.. It uses a Detriot Locker with
4:10 gears and Moser 31 spline axles. The rear brakes are Wilwood with internal parking brake. The front brakes are stock Corvette. The front frame rails and crossmember are from Progressive Automotive. It is designed to use C4 Corvette
suspension. The front control arms are polished aluminum C4 Corvette items. The front and rear use Strange Automotive
coilovers.
Very nice! Will it be a car or truck? Looks like maybe part of a car body in one picture.Proud NON-CASO
Romans 15:13
Deuteronomy 31:6
Proverbs 28:1
Illegitimi non carborundum
Very Nice Stephen.
Same chassis combo as I hope to use on my 56 Power Hawk (plus sheet metal combo too)
Want to see more pictures of your front end install. And some of your tech info.
Please e-mail me directly if it is easier.
Thanks
BrianBrian Woods
woodysrods@shaw.ca
1946 M Series (Shop Truck)
Brian, here is a link to the beginning of the front frame rail swap. I will be glad to furnish you any tech info I have access to. There is also a link to some of the work done by the young man that installed the front. The third picture from the left is the beginning of the chassis that follows. He is good, very good.
