I added a backup light switch to my T9:
Basically, I drilled the lock pin access hole to be taped with a 1/4" pipe tap, screwed in a brass 1/4" pipe section, and mounted the push button switch to the end of the pipe. I made the actuator rod out of a long bolt with the head cut off and rounded on the end that contacts the reverse shift rod. I had to remove the reverse shift rod and grind a detent in it for the actuator rod.
Works perfectly!
BTW, the front of the housing does not have plugs for the shift rods and the parts manual only calls out the three on the rear of the housing. This seems odd to expose the shift rod to the elements. Has anyone made anything to cover the holes?
Works perfectly!
