I want to remove the entire front clip on my 62 lark for the engine swap. Due to limited garage space I need to hang the clip from the ceiling or on a wall, so I'm curious what the weight of the whole clip is. Can anyone who has removed the clip give me an idea of the weight? Thanks.
62 Lark Front Clip Weight
Without the hood , about 100-120 lbs.....my wife and I easily lifted the clip off our 64 Daytona....core support and radiator in place.Bez Auto Alchemy
CAUTION: Many garage roofs are not trussed to support weight. Especially "newer" ones. Ask someone that understands building design.KURTRUK
Dougie, I see no reason that trusses or rafters, even ones that are 24" oc should have any trouble handling the weight of a front clip...after all how much did the roofing crew weigh that put the roof on in the first place??? You'll be okay. Junior.sigpic
1954 C5 Hamilton car.
Originally posted by junior View PostDougie, I see no reason that trusses or rafters, even ones that are 24" oc should have any trouble handling the weight of a front clip...after all how much did the roofing crew weigh that put the roof on in the first place??? You'll be okay. Junior.
I'm not worried about that. Garage is attached to house and has 2x10 rafters 16" on center. I just have to find them through the drywall. Empty attic above too.
