I installed the differential back into the car last night and mounted the wheels I had picked up at the local junk yard to make sure I didn't get any fender rub. The wheels are from a 87 Mercury Grand Marquis (hope I spelled that right).
No rub front or rear but while checking I discovered that I had about 1/2" more clearance on the drivers side rear than I had on the passenger side rear. I am thinking the body is probably not sitting on the frame right. Looks to be shifted to one side by about 1/4 inch. If that is not the problem, then I assume something is bent.
Anybody run into this before? Any suggestion on where to start looking?
The body of this car still has to come off the frame for restoration and if it is just an alignment issue I can take care of it when the body goes back on the frame. This is my first time doing this and I don't know if the body mounting holes would allow for a 1/4" misalignment.
Thanks
Wayne
Thanks
Wayne
