Does anyone know if a 57 Golden Hawk AD transmission can be installed on a 63 GT Hawk. I'm having unidenfied trouble with the rebuilt 63 transmisison (low and high not working, reverse is working ok) and have a extra rebuilt 57 GH tranny that, if compatible, could be installed on the 63GT. The labels on both trannys are obliterated but the 57 has traces of white color and has#60374; the 63 has traces of red color on the label and#1544019. Not sure color of labels is sifnificant or not but provided it anyway. The 63 tranny was taken apart by the rebuilder but he coud not find anything obviously wrong. Any input would be appreciated. Ken, Deltaville, Va
AD Transmission interchange
If that is the original tranny from the '57 Golden Hawk, it would be a short tailshaft trans that was used in conjunction with a 2-piece driveshaft. Stude went to the long tailshaft/single piece driveshaft starting in '58.
While I suppose a short tailshaft tranny can be made to work in a '63 GT if you installed the center crossmember for the 2-piece driveshaft, it would seem to be more trouble than it would be worth IMHO.Paul
Winston-Salem, NC
Check out my YouTube channel here: https://www.youtube.com/user/r1lark
Originally posted by r1lark View PostIf that is the original tranny from the '57 Golden Hawk, it would be a short tailshaft trans that was used in conjunction with a 2-piece driveshaft. Stude went to the long tailshaft/single piece driveshaft starting in '58.
Originally posted by okc63avanti View PostIt's a shame the rebuilder didn't get it right but I would imagine there are several reputable vendors with the right trans for your 63 GT that would have a good working trans for a reasonable price.Last edited by ken-renda; 02-09-2011, 12:25 PM.
There should be NO reason that someone capable of rebuilding one of these, could not go back in and FIND his mistakes! It only can be so many things with that condition, like FORWARD band adjustment, incorrect valve body assembly etc. Get a bigger stick, and MAKE HIM FIX IT!
Also, I have heard that sometimes after a rebuild, it takes running the car on a hoist to spin it up through the gears to free it up or remove air in the system or something to make it shift. There are posts here that explain it better than I can remember it.StudeRich
