Trying to find a gear set to make my pickup more road worthy. Anyone know who made the rear ends in 1950?
Who made the differential for Studebaker pickups in 1950?
Trying to find a gear set to make my pickup more road worthy. Anyone know who made the rear ends in 1950?Studebaker bought them from Dana-Spicer.
No, for the 3/4t and 1t, they are from Timken.
Maybe, In a technical discussion, terminology is everything. Helps to begin with your model number. Next, what transmission? If a 3-speed or 4--speed, going to an overdrive is the easy answer.
jack vinesPackardV8
No I don't it was a couple of years back. But I am sure Lester Gear in Tulsa could help. You could call Lester Gear Front wheel Shop they have a lot of rear end parts and can order them. If I remember right it was something like a 4-10 gears. The pick up we put it in was a big 6 3 speed overdrive. It run out real good.
Actually, the 4.82 ratio in the Dana rear end works very well with overdrive and your Champ 6 engine. The 0.7 overdrive gives you a net 3.37:1. With 31" diameter tires (6.50-16 or LT215/85R16 with rolling radius 14.3") you'll be going 68 mph at 2500-2700 rpm. The engine doesn't have enough torque to cruise at 1500-2000 rpm like modern cars. By late 1950, you could have a Dana 44 rear end with 4.89 ratio (s/n R5-65,214 and higher). If your serial number is lower, then you have a Dana 41 - and there aren't many alternate gear sets available because the carrier needs to be changed, too. You can see a 41 or 44 cast into the housing (lower right side on back).
Have you driven it with the overdrive working?Gary Ash
Dartmouth, Mass.
’41 Commander Land Cruiser
'48 M5
'65 Wagonaire Commander
'63 Wagonaire Standard
Originally posted by garyash View PostActually, the 4.82 ratio in the Dana rear end works very well with overdrive and your Champ 6 engine. The 0.7 overdrive gives you a net 3.37:1. With 31" diameter tires (6.50-16 or LT215/85R16 with rolling radius 14.3") you'll be going 68 mph at 2500-2700 rpm. The engine doesn't have enough torque to cruise at 1500-2000 rpm like modern cars. By late 1950, you could have a Dana 44 rear end with 4.89 ratio (s/n R5-65,214 and higher). If your serial number is lower, then you have a Dana 41 - and there aren't many alternate gear sets available because the carrier needs to be changed, too. You can see a 41 or 44 cast into the housing (lower right side on back).
Originally posted by TX Rebel View PostI have a few 1/2 tn rear ends in stock. If you have a 3/4 tn, it would be good to retrofit a later model or brand X rear end into your truck unless you can find some highway gears for your old Timken rear end.
Tom Walgamuth
76five 49zero 02seven5Diesel loving, autocrossing, Coupe express loving, Grandpa Architect.
