I am not sure I will ever finish. I replaced everything on the brake system of a 57 Silver Hawk. I just cannot get the brake pedal up more than about 4 inches from the floor on first push. I have bled the brakes using more than a quart of fluid. I have the shoes adjusted out until you can hear the shoes drag but the drum still turns easily.
I have the MC push rod adjusted in until there is only about one eighth of an inch of free pedal (per the shop manual). I tried adjusting the push rod in further which raises the pedal but then when I push and release the pedal, the drums are hard to turn until it sits for awhile and then the pressure goes off of the shoes and they turn freely again.
I am afraid to adjust the shoes out any tighter as it will put a lot of drag on them which could cause a problem.
Any suggestions would be appreciated. Thanks
