I have a 6 cylinder automatic 62 lark with the suspended brake pedal. I'm going to be converting it to a manual trans with Chevy V8 and looking at the brake pedal assembly and the workshop manual, it looks like the bracket that holds the automatic brake pedal is the same as the one used for the manaul brake/clutch pedal. It looks like the shaft that goes thru and is used as the pivot for the auto brake pedal is simply replaced by the shaft that is attached to the clutch pedal. Is this correct? If so, I'm thinking I could insert a clutch pedal and shaft and then trim the wider brake pedal down to match the clutch pedal and put a new rubber pad on it. I plan to use a hydraulic clutch so i know I need to figure all the details of that out, but I think this would be a great start, and retain the stock look without having to rig up universal pedals. Will this work? Thanks.
Lark Brake/Clutch Pedal Question
Hi Dougie,
I will try to look for you when I go out to feed the Horses in the morning,
I have two 62 larks 1 is a 3 speed over drive & the Daytona is an automatic you know my hot rod with the chevy 350 in it...
The 8.8 is in with all the brakes and I found the drive shaft and it's in too.
So it will be some fun this summer.
I will compare them and get back to you ok.
Gene.
StudeRich - Thanks. I was hoping to hear that.
Gene, No need to go climbing around to check the manual car unless you just feel like doing it. Glad to hear you made some good progress on the black Lark. I'm moving a little slowly, still working on the engine, but progress nonetheless.
Unless I missed it there is one small difference in the upper bracket shell that runs from the dash to the firewall... the standard shift has a arm off the clutch pedal side for a clutch return spring. The standard pedals will fit right into the automatic shell but there is that return spring for the mechanical clutch. Since you mentioned a hydralic clutch, I dont know if the return spring under the dash is necessary.
Jeff T.\"I\'m getting nowhere as fast as I can\"
The Replacements.
clutch and brake pedal
Originally posted by Jeff T. View PostUnless I missed it there is one small difference in the upper bracket shell that runs from the dash to the firewall... the standard shift has a arm off the clutch pedal side for a clutch return spring. The standard pedals will fit right into the automatic shell but there is that return spring for the mechanical clutch. Since you mentioned a hydralic clutch, I dont know if the return spring under the dash is necessary.
Jeff T.
