Good morning. I got the fuel system all squared away, and it runs nice. But it bogs down a lot (can't drive it) when I put it into gear. Actually, it did drive reasonably well at neighborhood (25mph) speed but when I stepped on it
out on the main street on a test drive, it wanted to bog down. Troubleshooting back in the yard showed that the
engine runs fine but the load of the tranny bogs down the engine really badly.
It is a 6-cyl with a DG-200 automatic. I did notice a previous owner disconnected the accelerator kick-down rod and removed the bracket that mounted that rod to the tranny's governor. The tranny shop manual says the nut on that rod is used to set the idle, along the with the idle screw at the carb. Could the missing bracket and inoperative governor be causing it to bog down, since I cannot set the idle without it? Anyone have a kick-down rod (appears bent) and the associated tranny bracket/bolts they would part with?
Also, could the disconnected kickdown rod and governor be related to not feeling it shift into "Third" when I test drove it previously? Shifted fine 1st to 2nd, but seemed to rev too high at 45-50mph and felt like it never shifted.
My plan is to reconnect the governor, replace the screen, and adjust the bands and see if that does it. Otherwise, I found a guy who has a lot of experience with very similar transmissions in his Ramblers and other old cars who is willing to do the rebuild locally. Reverse works, but it won't back up on an incline. I don't see any evidence of the switches, etc. that ran the anti-creep, so it appears all that was removed long ago and should not figure into the troubleshooting. I already replaced the fluid (it was low, and they'd been running oil - I replaced with Type F) but I'll have to do it again when I replace the screen, which I should have done at that time. It did not seem to bog down like that when I test drove it when low on fluid (didn't know it was low at the time, believing they were running a clear fluid) but I guess the drag is greater when it has the proper amount of fluid in it?
Regards,
Clarence in Virginia Beach
Regards,
