for a 1960 studebaker latk 6 cyl. wagon
Need Correct battery deminsions
It is a standard Group 24, avoid the 24F (Ford) the terminals are backwards, the GROUND Post should always be forward and inboard on all Studebakers, NEGATIVE on 12V and POSITIVE on 6V. Also avoid the "Generic" Batteries with the posts centered on the width.
The ones with no protruding cell covers will be easier to fit the OEM hold-down bracket.
An Interstate Battery works, also the last I checked, a Sears Die Hard Weatherhandler also does, they do not make the 24 in the top of the line Silver or Gold.Last edited by StudeRich; 12-04-2010, 10:16 AM.StudeRich
Group 24. 10 1/4" L; 6 13/16" W; 8 7/8" H. I have purchased 2 recently at Auto Zone. Interstate,Auto Zone,Checkers,Sears,AC-Delco are all now made by JCI(Johnson Control). Walmart and some of the others will try to sell you a group 34. Same length and width but an inch too short.
Denny L
Originally posted by Green53 View PostGroup 24. 10 1/4" L; 6 13/16" W; 8 7/8" H. I have purchased 2 recently at Auto Zone. Interstate,Auto Zone,Checkers,Sears,AC-Delco are all now made by JCI(Johnson Control). Walmart and some of the others will try to sell you a group 34. Same length and width but an inch too short.
Denny LGary L.
There is not a battery box on a 1960 Lark front fender that I am aware of, but here's a pic of mine. It's not a Willard, but is an original Delco that I found dry in its original box. The rest of the V/8 Lark components are Delco so I went with it.
10-1/8" long. 6-3/4" wide. 8-1/8" high, Phil. Hope that helps.Last edited by barnlark; 11-28-2010, 09:36 PM.
None of the Larks or Champs have any Battery boxes, they sit on the inner fender. There is a small hole below the shelf for the "J" Bolt that holds the Battery hold down bracket on the engine side and a stud on the inner fender for the outboard wingnut.StudeRich
You may have to go to a shop that specializes in batteries; not a mainstream automotive chain like AutoZone, Pep Boys, etc. These outfits mainly cater to the truck and industrial equipment market and will keep 'genuine' AABM 24 and the larger 27 batteries in stock. I have to use actual 24 batteries in Big Bertha as the batteries themselves along with the spacers support the cover.
Illustration from 8E Shop Manual:
With cover installed:
CraigLast edited by 8E45E; 11-29-2010, 07:10 PM.
I bought a red top Optima battery for my 6V 55 Conestoga, I knew they made cases for the Optima to look old and I thought id get one of those later. But when i got the Battery (From Jegs for $148) it would only fit cross wise (and very tight [\] ) in the battery holder for a 55. Looks strange and it wouldn't fit in a case and go into the battery holder. The car perked up and Started much easier that it did before.101st Airborne Div. 326 Engineers Ft Campbell Ky.
