View Full Version : brake pedal question
Gallivan
11-18-2010, 08:36 PM
Putting the brake pedal back on (w/ new bushings) the shaft that's welded to the frame. The hole in the shaft was full of old grease, when I cleaned it out, there are bushings inside the shaft as well (about 5/8" ID)!
The parts book only shows a 3/8" bolt that goes thru the hole- should there be something else?
Studeman
11-19-2010, 01:49 PM
"The parts book only shows a 3/8" bolt that goes thru the hole- should there be something else?"
Only if it's a manual transmission.. The shaft for the clutch linkage runs "through" that pivot-bracket... that's why the bushings are in there. If it's an automatic... they just install a bolt.
